WHIRLPOOL 3558203 4.2 CU. FT. WHIRLPOOL FRONT LOAD WASHING MACHINE WITH CLOSET-DEPTH FIT - WHITE
Features- 4.2 Cu. ft. Whirlpool Front Load Washing Machine with Closet-Depth Fit - White
- Adaptive Wash technology senses the needs of each load and adapts wash actions
- Precision Dispense holds detergent and additives and releases detergent at the correct time during the cycle
- The Smooth Wave stainless steel wash basket gently guides clothes through the wash cycle and helps protect fabrics from fraying and snags
- Get a space-saving design with closet-depth fit that allows for more flexible installation in your laundry space
Specifications- Capacity: 4.2 cu. ft.
- Coin Operated: No
- Color: White
- Energy Star: Yes
- Stackable: Yes
- Voltage: 120 Volt
- Weight: 245 lbs
Price: 1353.16
