WHIRLPOOL LTG5243DQ WHIRLPOOL COMBINATION GAS WASHER - DRYER WHITE 5 WASH CYCLES
Features- Rotary controls are easy to use and provide convenient access to all cycle and option selections
- Gentle Wash system provides optimal care for delicates while also thoroughly cleaning tougher fabrics like jeans
- 5 wash cycles including Normal Soak Delicate and Permanent Press provide optimal care and cleaning for a variety of fabrics
- 5 washer spin speed combinations provide flexibility to match the variety of fabrics you wash
- 3 water levels allow you to select the right water level for your load size helping to eliminate water waste
- 4 water temperatures ensure thorough cleaning and care for all your fabric types
- Surgilator agitator creates a continuous rollover action that provides a thorough cleaning of the wash load
- 18 dryer cycles including Timed Dry Permanent Press and Air Only handle a variety of fabrics
- Combination
Specifications- Color: White
- Door Style: Left Swing
- Dryer Capacity: 3.4 cu. ft
- Voltage: 120 Volt
- Washer Capacity: 1.5 cu. ft
- Country of Origin: USA
Price: 1706.93
