WHIRLPOOL MEDC215EW MAYTAG 7.0 CU FT. LARGE CAPACITY ELECTRIC DRYER WRINKLE CONTROL WHITE
15 Dryer Cycles including multiple timed dry options heavy duty energy preferred auto dry less dry - auto dry more dry air dry normal and damp dry.
With the Wrinkle Control option the dryer continues to tumble your clothes after the cycle has ended. It's a no-heat way to help prevent wrinkles from setting in.
Features- Limited Warranty
- 15 Dryer Cycles including multiple timed dry options heavy duty energy preferred auto dry less dry - auto dry more dry air dry normal and damp dry
- Dryer drum's powder-coat finish resists chipping and abrasion to protect clothes from damage
- Rear panel controls provide convenient access to all cycle and option selections
- 4 temperature settings: air only high low and medium allow you to choose the best drying temperature for each load
- AutoDry sensor tracks moisture levels to stop the cycle at that perfect point of dry
- Set the end-of-cycle signal alerts you when the drying cycle has completed
- Maytag Commercial Technology. These dryers come standard with high-performance commercial-grade parts
- Interior drum light illuminates the interior of the dryer to make loading and unloading easier. Reversible side-swing door increases installation options
- The heavy-duty motor provides faster spin speeds which work together with optimized airflow for exceptional drying
- Maytag Large Capacity Electric Dryer
Specifications- Capacity: 7.0 cu. ft
- Color: White
- Energy Star: No
- Voltage: 240 Volt
- Country of Origin: USA
Price: 773.25
