WHIRLPOOL WED75HEFW WHIRLPOOL 7.4 CU. FT. FRONT LOAD ELECTRIC DRYER WHITE 6 DRYING CYCLES
Wrinkle Shield option helps keep wrinkles from setting in to clean clothes with intermittent tumbling after the dryer cycle ends. The process lasts for up to 140 minutes or until you open the dryer door. Tap Touch control interface brings high-tech style to your laundry room. It provides direct access to dryer functions and its sleek appearance enhances the appeal of any space. Advanced moisture sensing monitors moisture levels inside the dryer. This helps the drying cycle end when everything is perfectly dry saving time energy and helping to prevent overdrying.
Features- Limited 1 Year
- 6 cycles: Timed Dry Quick Dry Normal Bulky Heavy Duty and Delicates to provide great drying performance
- Dryer drum's powder-coat finish resists chipping and abrasion to help protect clothes from damage
- 4 temperature settings to handle variety of fabrics from delicate synthetics to heavyweight cotton
- Quiet Dry Plus noise reduction system: sound absorbing materials are strategically placed around the dryer drum to reduce operational noise
- Front Load Electric Dryer
Specifications- Capacity: 7.4 cu. ft
- Color: White
- Energy Star: Yes
- Voltage: 240 Volt
Price: 1133.21
